JSchleim18
Well here it is. After many years and a verrryyy slow build process, it's up to satisfactory level for myself. I have a bunch of work (mod list to come later) done to her.
Exterior stuff:
JDM RS Front Bumper
JDM Amber Corners
JDM Eterna Grille
Fiberglass JDM hood with Aerocatch hood pins
JDM Rear Bumper
Volk TE37 16x8 +35 wrapped in Dunlop Z1 Star Specs
Engine:
JE 9.0:1 Pistons
Eagle Rods
ARP Studs, MLS Headgasket
ARP Main studs, rod bolts
Factory crank, polished
HKS 264's, BC Springs/retainers
Kiggly HLA regulator
SS 1mm oversized valves
3G Lifters
JAZ Catch can recirculated to oil pan, "Hal" custom vented oil cap
New oil pan
Trans:
TRE Stage 3 2G AWD DSM trans
Comp Clutch 1620 (6 puck sprung disc and 2700Lb pressure plate IIRC)
new clutch master cylinder
Intake:
OEM intake manifold, Magnus spacer
throttlebodys.com rebuilt N/T throttle body
2.5" aluminum IC piping
4" aluminum intake pipe, K&N Filter
Custom made ETS Intercooler (based off 1G race intercooler, just 3")
Tial BOV (latest model)
Exhaust/turbo:
BR20G
FP Race manifold JNZ finishing ceramic coating
SBR o2 housing open dump
Tial 38mm wastegate
Custom 3" turboback exhaust with Borla resonator and Apexi N1 muffler
Suspension:
Tein HA coilovers
W/L Swaybars (22mm F, 26mm R), whiteline spherical endlinks
Whiteline caster adjustable front bushing
Energy suspension front subframe bushings
boostx rear subframe and mustache brace bushings
maximal performance adjustable rear control arms
Jay Racing active toe elimination kit
New ball joints everywhere, tie rod ends (inner and outer)
DSM 5 lug setup (fronts are FWD)
Cusco front and rear strut bars (front needs to be put on)
Fuel:
Denso 720cc
Denso Supra TT fuel pump
Fuelab Fuel Pressure Regulator setup
Misc:
DSG Shift knob
Optima battery relocated to trunk
GReddy gauges (boost, Oil pressure, oil temp, water temp)
AEM Wideband gauge
1G leather shift boot
89 glove box and underdash
I have a bunch more I am forgetting and some stuff that needs to go on the car include:
fiberglass trunk
OMP steering wheel and hub adapter
Schroth harnesses
Boostx Lip
3000GT VR-4 calipers
JDM Fuel door
door handle scratch protectors
Rallyarmor mud flaps
Ceramic coating sucks...period. Next time I am getting Swaintech coating.
There are still quite of few things to still go into the car and be done (like painting the window trim). It is on ECMLink v3 Lite and is running speed density.
BTW - car will get paint next year...hood will be white!
Exterior stuff:
JDM RS Front Bumper
JDM Amber Corners
JDM Eterna Grille
JDM Rear Bumper
Engine:
JE 9.0:1 Pistons
Eagle Rods
3G Lifters
New oil pan
Trans:
Intake:
Exhaust/turbo:
BR20G
Tial 38mm wastegate
Suspension:
Tein HA coilovers
Fuel:
Denso 720cc
Misc:
DSG Shift knob
AEM Wideband gauge
fiberglass trunk
Schroth harnesses
Boostx Lip
JDM Fuel door
