The never ending build of 1062.
AWDnoobie
Alberta, Canada
Nice to see the beast coming together bit by bit. A question for ya, what kind of welder you using mig/tig?
Galantvr41062
plymouth, MN
I have an Airco 250 TIG welder here at home, that is what I have used the most on the car. If it has been mig welded I had a Miller 250 MIG welder at the shop.
~John
AWDnoobie
Alberta, Canada
Thanx for the reply John, im looking at buying a Miller180 in the next few days. Maybe one day ill have fabrication skills like you and your buddies. Anyways keep up with the updates, your building one hell of a vr4 /ubbthreads/images/graemlins/worthy.gif
Galantvr41062
plymouth, MN
My gears shipped last friday, and I received them Wednesday this week. So here is the update, not much left then its off to the dyno and the track to see what this thing can do at "low" power.
Thanks for looking
~John
Barnes
Richland, WA
Hey John, how do you feel about adult adoption? /ubbthreads/images/graemlins/grin.gif
Barnes
Richland, WA
Dsmgst, the diff Norway asked about is the front diff. This does not affect power split. I suspect that welding is insurance to keep the bolts that hold the 'ring' gear to the diff from loosening. Also, with the pinion cross shaft welded there is no chance it could fall out of the diff housing. Looks like extreme measures in insurance to me.
Not a bad idea when overhaulin the box /ubbthreads/images/graemlins/smile.gif
Very nice build by the way /ubbthreads/images/graemlins/worthy.gif !!!
Galantvr41062
plymouth, MN
Thanks. The front diff is welded to ensure nothing lets loose and breaks important parts in the tranny. I did weld my center diff for a 50/50 split and to make sure it does not break either.
~John
Looks great! I'd love to do this with my gvr4 thats been sitting around forever drivetrainless.
Do you have any pictures of the welding on the center diff ?? /ubbthreads/images/graemlins/smile.gif
Galantvr41062
plymouth, MN
Here are the best 2 shots I have. I use a MIG welder to weld the lower spider gear to the diff housing, this is what drives the front pinion. Then I use a TIG welder to weld the top spider gear to the top of the diff, I weld the bottom and the top of the gear to give this as much strength as possible. It is the top of the center diff that drives the output shaft going to the transfer case.
~John
Galantvr41062
plymouth, MN
Yes I re-shimmed the tranny, its on the tight end of the spec to help save the gears.
~John
curtis
Clarksville TN
I love that tread design every time I see a car with them I just smile.
^I was thinking the same thing. I had a set of Avon's on my BMW 2002 that had that pattern and it looks like it means business. Of course missing the fron clip of a car and having it tube framed says the same thing. /ubbthreads/images/graemlins/smile.gif
AWDnoobie
Alberta, Canada
What are you doing for brakes for staging? Im thinking of going with dual line locks once I delete my abs lines. Car looks to be getting close to done, cant wait to see more pictures...
Galantvr41062
plymouth, MN
I will either put the parking break cables back in, or wire up for a line lock on the front breaks. I will try it at the track to see how it goes first. I drove the car up and down the street a few times, now I just have some finish up work and take it for a full test drive.
~John
Galantvr41062
plymouth, MN
Rear window is done, hood is fitted, break lights, turn signals, and running lights are wired up in the back.
I have dyno time setup, then after that its off to a track to see what it can do.
~John
