TH3 Lazy arse Australian / New Zealand Picture build thread
RedTwo
New Zealand
That turbo looks huge in the thumbnail, I don't want to make it any larger! /ubbthreads/images/graemlins/ooo.gif
NZ VR4 RS
new zealand
done a few more things on the car over the weekend.
finally fitted bonnett catches and seat, plus came by some rods and pistons for the rebuild. :-o
good old eagle/je combo
3diamonds
Active member
Newcastle, Australia
3diamonds
Active member
cheers Baz..
yeah i didn't want to attract to much attention. it gets enough attention from how it sounds on idle but the electronic silencer is helping out on that.
everything else is still stock as far as interior and aircon goes
just got a set of evo 1 wheels, also with some bigger tyres on it now then in that pic
bustedsm
Ripley, Tennessee
Your front axles WILL hate you and you WILL go through them very quickly. Two in the past 1300 miles here...
RedTwo
New Zealand
Sitting on the dyno and they tell me I've blown the head gasket /ubbthreads/images/graemlins/frown.gif
So once that gets added onto the existing bill I will be tell the kids they'll be having an imagination Christmas this year /ubbthreads/images/graemlins/bawling.gif /ubbthreads/images/graemlins/rofl.gif
bazeng
Melbourne, Australia
That sucks... Who's doing the tuning? What ecu again?
Checkout the damage on the vr4 rs box that occurred on the dyno.
Look what I just found in a gearbox out of a vr4 I have purchased....
This should hopefully fix the problem....
NZ VR4 RS
new zealand
Quoting RedTwo:
WHAT IT WAS BLOWN BEFORE YOU GOT THERE OR THEY BLEW IT ON THE DYNO.
i got some arp headstuds cheap if you want them brand new.
ditto on what ecu and workshop
NZ VR4 RS
new zealand
Quoting bazeng:
had to be an ex rally car box, is it a ppg set
bazeng
Box finally inspected and kaaz front lsd installed.
All that was required was to swap out the pinion shaft bearings and a 3.5 conversion to the lsd so basically crown wheel and pinion swap from the broken box.
Time to put it in the car!
VR42LT
Australia
Nice Baz i so what a dog box but i cant justify the coin /ubbthreads/images/graemlins/dunno.gif
In the mean time here a few updates of my own.
H05TYL
Wgtn, NZ
Had my heap on the dyno yesterday, was rich as hell (afr high 10's low 11's) - proof 510's and an evo afm don't cancel each other out when used with an ecu expecting 450's.
Tweaked it as best we could with the old school s-afc (afr ~12.5) and it made 189kW with boost spiking to 18psi then dropping back to 15psi by redline. This dyno reads about 10% down on the one the cars previously been on, so by just adding reground cams, tweaking the fueling very roughly and 1psi more boost in the midrange and 1psi less up top it's making 30+kW more than before. Couldn't add any more boost as it would start to knock when it spiked any higher.
There's a whole lot of my current setup that is less than ideal (stock wastegate is just wired shut until I cbf to fit the welded exhaust housing I have, stock j-spec intercooler and teeny tiny piping, bleed valve to raise boost, rudimentry fuel control, no ignition adjustment, 1 manifold stud gone awol), so there's certainly more in there.
Will post the graph's when I get home.
