calcaliente
Active member
Bored so i decided to post up my work thus far. I never really introduced my self i just kinda lurk here and buy parts. Most of my parts i bought here or tuners. So yeah check it out and feel free to comment! /ubbthreads/images/graemlins/tongue.gif
Head
BC springs
HKS 272 cams
Arp head studs
Evo 8 retainers
New NGK spark plugs & wires
Evo 8 Injectors
Mitsubishi composite head gasket
Short Block
Wiseco HD's 8:5:1 .20 over
Manley Turbo tuff I beam rods
Stock crank inspected polished and straightened
ACL race bearings stock size
Brand new Mitsubishi Oil Pump with new Straight gears
Brand new Mitsubishi Water Pump
Brand new Mitsubishi timing components with Evo 9 timing belt
Fluidampr pulley with ARP balance bolts
Brand new Mitsubishi oil strainer
Brand new Mitsubishi oil pan bolts
Balance shaft delete
Brand new stock clutch with ARP flywheel bolts
Cometic full gasket set
Fp 4 inch intake for speed density
Genuine MHI Evo 3 16g
Greddy black sleeper front mount intercooler
Exhaust
Fp manifold
Punishment racing 02 housing
Tial 38mm 2 bolt ext waste gate
Full 3 inch slip fit exhaust
Electronics
AEM ECM
Trigger disk for AEM
GM SD 4.5 bar map sensor
AEM Boost gauge
AEM Oil pressure Gauge
AEM Wideband gauge
Battery relocated to trunk
GM IAT sensor
ABS deleted
A/C deleted
Power steering deleted
Extra goodies
APR FPR
Brand new shifter cables & clips
Walboro 255 fuel pump re wired
Prothane motor mounts
Mishimoto Coolant over flow can
Catch can
Racing steering wheel
AWS deleted
4bolt rear
5 lug swap
AFCO racing radiator with brand new radiator hoses and clamps
Engine bay painted black
Evo 8 wheels
Evo 8 suspension with Tein springs
Stainless steel brake lines
Stainless steel clutch line
Brand new Mitsubishi Clutch master cylinder
Brand new clutch slave cylinder
Redline shock proof in transfer case
Redline mt 90- MTL cocktail mix in transmission
10-30 Advance auto conventional oil (for break in)
10w-30 Mobil 1 synthetic oil
Head
BC springs
HKS 272 cams
Arp head studs
Evo 8 retainers
Evo 8 Injectors
Short Block
Exhaust
Fp manifold
Electronics
AEM ECM
AEM Boost gauge
AEM Wideband gauge
GM IAT sensor
ABS deleted
A/C deleted
Extra goodies
APR FPR
Catch can
AWS deleted
4bolt rear
5 lug swap
Evo 8 wheels
