Bazeng Update - VR4 +T51R SPL. - start up and idle video with new cams.
bazeng
Melbourne, Australia
evo8ya:
Genuine Mitsu badges. A friend of mine works in spares. I'm trying to get my hands on a new AMG spark plug cover. I've just got to give him my VIN number.
redtwo:
yes, they lock up the passive arms with the 4ws. The 4ws rod has been removed.
bazeng
A quick update!
The VR4 has had a 5 stud conversion with EVO V rims.
Thanks to all those guys from this board for supplying the rear axel shaft and brake parts!
I've also done a bit more to the engine but that will be revealed once it is up and running.
Enjoy the pics!
Water pump setup
Twin BOV setup
5 lug rears
Power steering cooler + MOTEC Sports Dash Logger and MOTEC Shift Light Module
5 lug front conversion + vette brake upgrade
Polish
NE, IN
Looking good man. /ubbthreads/images/graemlins/cool.gif
Getting closer.
curtis
Clarksville TN
Baller /ubbthreads/images/graemlins/worthy.gif
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
/ubbthreads/images/graemlins/blush.gif
belize1334
Bozeman, MT
So have you done away with the A2WIC entirely or are you gonna run it in series with the FMIC?
RedTwo
New Zealand
Bugger! You beat me to the first 5 stud vr4 in the southern hemisphere /ubbthreads/images/graemlins/jawdrop.gif
Why those two BOVs? They look pretty small - do they have a combined greater area/cost than a huge Tial or similar?
This car will be awesome when it's done /ubbthreads/images/graemlins/laugh.gif
bazeng
Thanks for the kind comments guys!
I have removed the W2A intercooler system completely and now run a FMIC in series with a DRY ICE / Air intercooler.
I chose to go 5 lug simply because I found difficulty sourcing 4stud rims to suit the big breaks.
As for the 2 bovs, I chose to go 2 because I am able to plumb them back if required (legal issues).
They are 38mm x2.
The aim is to keep the car a sleeper on the street.
But I think it'll be quite hard with the new wheels / brakes...
RedTwo
New Zealand
You could put the biggest t-wing in the world on the back, a dog eating turbo coming out of the bonnet and still no one will expect a mitsu-shitty to leave them in the dust.
Did Mitsubishi kill every second born child in Australia in 1992? Even though the R32 Skyline GT-R was so unstoppable it could still win races without getting on the track, the mitsi is the one so universally hated over there!
bazeng
21-10-09
Ok boys,
I got home from South Australia today and quickly said hi to the family and went straight to the VR4!
I've been hanging to fire it up with the adjusted config file for the Autronic SM4.
I ran over a few things, chucked the timing light on, checked a few settings on the SM4 and got the MRS to crank it over. The timing was slightly off which would have caused the problem so I adjusted it until the light saw what the SM4 was seeing. I plugged in the fuel pump fuses and told the MRS to crank again.... still not starting!!!
Hmmmmm.... I checked the CAS with the internal scope on the SM4 and it looked good... it was getting all the inputs that it should be getting... then I quickly remembered, the CAS might be off by 180 degrees!!!!
I quickly pulled the CAS off, spun the shaft 180 degrees out and reinstalled it.
I then pulled the fuses of the fuel pump and checked timing once again. Got it to 10deg btdc and locked it up. I then plugged the fuses back in and told the MRS to turn it over again... and guess what boys?!?!? ITS ALIVE!!!
My Long rod 2.4L (Self built with Springy Motors) is alive!
It sounds good, the exhaust is louder than I wanted but that is the last of my concerns right now. That is with the valve fully open anyway.
The engine is less noisy than my last build (thighter piston to bore). Seems to be revving quite effortlessly without load.
No oil leaks, no fuel leaks. Ballbearing turbo sounds nice after shutoff. Not as nice as my previous turbo imo.
There is one water leak at the thermostat housing (water temp sensor) I'll have to pull the sensor out, reseal and see how that should be ok.
There is no air idle control, I've yet to adjust the throttle stopper to keep the throttle slightly open for base idle. The Autronic SM4 works by using ignition to control idle which has to be tuned.
Check out the video fellas.
I'm done for today. Time to enjoy the arvo/night!
Might go see MJ's movie.. lol
I'll start on the Motec SDL tommorrow.
Finish off the drivetrain on Monday (fluids, trailing arm and rear brake shims)
Then hopefully get it on the ground on Tue and take her for a spin. Or I might give Dan from Springy Motors a call, get him to bring the o2 sensor over and he can tune it while driving and take it to the shop at the same time.
curtis
Clarksville TN
Need in car camera footage for sure. /ubbthreads/images/graemlins/worthy.gif
JB
MA
One of the best. /ubbthreads/images/graemlins/applause.gif /ubbthreads/images/graemlins/applause.gif /ubbthreads/images/graemlins/applause.gif
Ralli380Gvr4
Can't wait to this one on the road!!!
Polish
NE, IN
That thing sounds tough. /ubbthreads/images/graemlins/worthy.gif
bazeng
1-11-09 - `7-11-09
VR4 Dash Install
Ok, I started the MOTEC DASH install.
Firstly, getting the loom organised.
I decided to log
SDL sensors
- oil pressure
- oil temp
- fuel pressure
- air temp after turbo
- air temp after front mount intercooler
- air temp after dry ice cooler
- exhaust gas pressure before turbo
- exhaust gas pressure after turbo
SM4 datastream - SDL input
- rpm
- ground speed
- voltage
- manifold absolute pressure
- manifold temp sensor
- engine water temp
- launch aim rpm
- boost aim setpoint
- ignition
- lambda
- + a bunch more
The tefzel wire is fantastic stuff. Very thin and easy to shape. I went through about 10 metres of heatshrink and this took me about 3 - 4 days on and off (a few hours a day after work)... Thanks to Springy Motors for providing me with the tools to terminate the connectors and also the materials...
Although I do alot of wiring for my fulltime job, Automotive and Telecommunications are quite different but I tried to apply some of my background in the vehicle.
The loom ready for work:
Oil pressure and Oil tempurature
Fuel pressure
Air temp before front mount intercooler IMG]http://i449.photobucket.com/albums/qq216/bazeng/DSC02955800x600.jpg[/IMG]
Air temp after front mount intercooler
Air temp after dry ice box
New Electric water pump sensor in thermostat housing
Engine coolant filter
ECU / Fuses / Relays / CDI setup
SDL - SM4 datastream connection
SDL working
Variable LAUNCH Control via potentiometre / SM4 displayed on SDL (took alot of programming on the SM4 / SDL to get it to display on the unit but it finally works!!)
Exhaust gas pressure sensors yet to be purchased and installed.
bazeng
17-11-09
VR4 ready for tuning
I organised a tow truck to take the car to Springy Motors.
The VR4 does drive, but I didn't want to glaze the bores (running very rich)...
Off we go to Springy Motors!!
