thomcasey's rescue of #1025 build
bobbybdemented
Active member
Magnolia, Tx
Quoting thomcasey:
Finally got around to putting the front passenger door replacement on. Unfortunately, I had to do some modifications at the mount points (top body hinge mount and both door hinge mounts) with washers to get the rear door pushed far enough back to allow it to be opened with the front door closed and to align them. I have never seen so much difference between doors from the same year and model of car. But the work was worth it. Now the doors shut like a vault and the gaps are much cleaner than before. Now I just need the rest of the windows tinted, plus some paint and body work on the right rear QP, roof and hood.
Looks like your frame is bent. Door dose not line up. You should take it to a body shop or find a better donor car...
Indianapolis, IN
Frame is good, already had it checked.
Indianapolis, IN
Gretchen is back to 4-lug.
Indianapolis, IN
1025/2000 is officially back on the road with all of the drivetrain from 100/2000. Now the disassembly of 148/1000 starts to ready for a little frame straightening and welding.
