909/1000 Build thread
jeverts
Hartford, WI
Thank you I will look into that...I have to go some sort of hard line. Something flexible will just not look right with a machined intake.
Fiascoxl
Stuarts Draft, Va
I like the idea of individual throttle bodies, this paired with equal length runners would be amazing. This would no doubt leave each cylinder with equal airflow without the need of a cad blueprint or virtual flow testing. I know runner size would have to be kept to a minimum but placing the tb (sans itb) at center of the runners underneath or over the top could solve that easily. Just a thought.
edit: then again this would never work without a chamber to speed up the in coming air and like said keep the motor happy at idle and part throttle.
EHmotorsports
Beaverton
here is a good thread on the progression of this Z cars intake/itb setup. click
jeverts
Hartford, WI
While I am waiting on my exhaust manifold to get done I figured I would start on my sending unit.
Op1
Op2
Op3 I put in the 3/8 NPT holes
I modified a OEM gasket to work with the holes that I riv nuted
Here is the finished Top hat
I have 2 other brackets that I need to make yet to hang the fuel pump. Once everything is test fitted I will send this out for anodizing.
I am still looking at bulk head wire fittings to and I didn't want to put the hole in yet till I find one that will work.
JamesFoster
ALL
Progress is looking great! Love that sending unit.
GSXftw
medford, OR
Doin very cool stuff, keep it coming
Mike Valencia will want a fuel sender unit too. /ubbthreads/images/graemlins/rofl.gif
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
Hell yeah! Looks like a great start to a fun project. I am also a fan of the machine work.
Keep it flowing, it looks killer.
Subscribed. /ubbthreads/images/graemlins/devil.gif
Never seen it done. I think running new lines has stopped many people from that. Don't see why not though. Just need new pressure/return lines and a relocated fluid resivour.
jeverts
Hartford, WI
Awesome that would work great. I Just need the PS out of the way to get the turbo and manifold setup the way I want it. Pictures will ensue.
Where will the alternator go then?
