NateCrisman
It seems I have effectively hit the reset button on 139, it back on the lift with the engine and trans completely apart. figured I'd start a new thread with progress pictures and keep updating it till the car is on the road again. So typical rebuild thread I guess for posterity.
The mess I started with. Rust/coolant residue all over the engine bay from a ruptured radiator end cap on the last run at the dragstrip.
After pulling the head, intake, and turbo system out:
Radiator FAIL. Blown HG pressurized the cooling system enough to pop the end tank right off the radiator in 4th gear.
Kicked HG:
Stupid me left straight tap water in the cooling system after that track day while the car sat in the driveway untouched for about a month.
Notice the freeze plug. /ubbthreads/images/graemlins/banghead.gif
Pile of parts to be cleaned and organized:
#139's "Default Position" /ubbthreads/images/graemlins/rofl.gif
To Do list before the car can be reassembled:[*]Need to order up an engine gasket set. Going to use a stock composite HG again since this car isn't going to see nitrous anymore.
[*]Clean all parts and engine bay...I can't stand a mess and it was so sanitary before the HG incident.
[*]pick up another used aluminum flywheel...this one has some buggered teeth on the ring gear...it's suitable for "racecar use" but I want to replace it since 139' going to be a DD car for a season.
[*]POR15 another stock shortblock
[*]obtain & POR a set of rubber engine mounts...the prothanes are going in my 1g. The car just vibrates to damn much with the poly engine mounts.
[*]Brent @ JMF is going to repair my old 3" turboback exhaust...needs a hanger rewelded.
[*]Crack open a couple used trans I have in the shop, I think one has a 4 spider center diff that I may put in the GVR4 and move the welded center over to the 1g racecar.
[/list]
Hopefully early February the car should be back to drivable condition. Funny, seems like it was just yesterday that 139 was up on the lift and completely apart...actually it was only about 550miles ago in August. /ubbthreads/images/graemlins/bawling.gif /ubbthreads/images/graemlins/bawling.gif /ubbthreads/images/graemlins/bawling.gif
Kicked HG:
[/list]
