AnotherNewb
Youtube
Set up:
14b turbo
2.5" IC pipes
Injen Intake with 2g MAF
HKS SSQV
1947 is exibiting these symptoms. It sounds like a horse whineying. After searching around I am unable to find a solid reasoning or solution to this problem (better BOV is not a solution). All the Vacuum lines are new, and the BOV is authentic. Also it is being recirculated with no noise insert. Has anyone had this problem with their car?The flutter dump is worse at part throttle but at wide open nearly nonexistant. The car has 17-20hg of vacuum so that isn't the problem and the BOV has a dedicated vacuum line to it (it might be tee'd off the line for the BC/WG).
Please discuss.
Set up:
14b turbo
2.5" IC pipes
HKS SSQV
Please discuss.
