1000 hp build for 100/2000
Iceman
Member
indianapolis, IN
I'm beginning to build a motor I have laying around for my GVR4. Here are my thoughts... also aquariumopen for suggestions.
4G63t 2.3L stroker short block
Manley 9.0:1 (.040) 86mm pistons
Manley H-beam rods
clevite main and rod bearings
Eagle 100mm stroker crankshaft
The block is o-ringed and balance shafts removed with AMS balance shaft eliminator kit.
Kiggly racing main girdle
Crowley 288 cams
AEM Adjustable cam gears
Precision 6266 turbo
Boostdtalon
Buckley, Wa.
Most of the build looks good, but I think you're turbo is going to fall flat of the numbers your wanting. From PTE's website, that turbo is only rated for 800hp.
mcbride89
Belmar,NJ
Gonna need more then that to break 1000. I'd go with 10:1 CR personally. Carillo rods. And a super99 and you may get close to that. There's so many damn variables. Besides what are your goals? I hope you plan to build the drivetrain and dump a ton of money into regular maintance that should come first.
gaylantvr4
Omaha ,NE
for that amount of power i would use hd pistons and some good rods the h beams will work but for how long.
Iceman
Member
indianapolis, IN
For some reason either my phone or something didn't allow me to send the other half of my original post.
There are several other mods that I've thought about installing. However, I can't seem to remember them at this time.
definitely going 2150cc FIC injectors
swapping to automatic using rvr trans and 3rd gen slap shift.
Thanks for the seggestions guys!
thecman02
Kalamazoo,MI
A turbo more suitable for your goal.
I would go for a set of Carrillo I beams. Definitely the Wiesco HD pistons. I would look for an oem 2.4 crank or if you must have an aftermarket crank your going to want to send it out to be balanced. I haven't been impressed with the balance from Manley.
You'll want to add nitrous to your build too because I've seen people having a hell of time trying to get up on converter even with high dollar aftermarket converters.
manikbastrd
Since you are gonna spend the money, I would look into the Borg Warner EFR turbos. The PTE's are notorious for bearing problems. Just my .02
EMX5636
Bucks County, PA
The PTE bearing problems are only the journal bearing cartridge IIRC. My ball bearing Precision has been holding up great.
jogalant
Central FL
Fuel to feed the beast. I wonder how much you'll need. Will 4 injectors be enough? /ubbthreads/images/graemlins/dunno.gif
biglady112
Commerce City, Co
Not enough fuel
Pistons are garbage
Rods are garbage
Turbo will only get the average person to about 60-65% of your goal
Most 1000hp 4G63's use multiple injectors
High compression is not needed. Another fad. If you run an alcohol based fuel is the only time you should need to go that high to reap the benefits.
Wiseco is also another garbage fad product. Not enough meat to really get crazy with things.
Stick with a 2.0L. Much simpler and more reliable to live a healthy life at that kind of power.
Your list is far too short for 1000hp. I know, I make 800hp/556tq.
manikbastrd
Why do you say that Wisecos are a fad and are garbage? I have(and many many others) run Wisecos in dirtbike motors for years (2 and 4 stroke) with no problems...
brisvr4
brisbane australia
Quoting biglady112:
Not enough fuel
Pistons are garbage
Rods are garbage
Perhaps some positive suggestions as to what he should run May have been better than a post full of negativity. /ubbthreads/images/graemlins/dunno.gif
mitsuturbo
Near Seattle, Washington
If it were me, (and i'm certainly no expert on 500+ hp setups) I'd lean more toward a set of Pauter X beam rods, a custom set of Ross pistons, and a GT42r based turbo. I've never heard of Crowley cams, and cannot find a presence on the web for them via google search, but AFAIK Kelford and GSC seem to be the leaders in 4g63 camshaft technology these days.
If you're shooting for over 900whp, you're going to run into a slew of drivetrain problems, i'm sure. I think the engine internals would be the least of your worries, to be honest. I'm sure you'd be looking at ridiculous spec driveshaft/axles, significant front&rear differential upgrades, not to mention the puny/weak transfer case that our cars are equipped with. If i had intent to build a beast like that, i'd seriously consider a dry sump setup (including an electric vacuum pump) an electric/external water pump, a boatload of AN lines and fittings, and a whole lot of cro-moly cage/chassis work as well.
As i said... engine internals for a high HP setup like that are likely the least of your concerns. I'm just a JSB bench racer though.
Maybe it's just me, but I think anybody shooting for 1000whp doesn't need to ask opinions on a forum such as this. I don't think I've seen a single guy making that kind of power start such a thread. They already know what's needed. Otherwise, I think you're in over your head. /ubbthreads/images/graemlins/dunno.gif
EMX5636
Bucks County, PA
Quoting turbowop:
-Truth.
But as I stated in your other thread, most H-beams will fold at those HP levels. Turbo needs to be substantially bigger. I'm not sure what "slap shift" you're referring to, but most guys with built autos, are going with a full manual (B&M etc) shifter and trans mods. The shift boxes aren't proving to be reliable enough for drag use. Start by building a 4-500whp car, and see if you have the pockets and time to double that.
coyotes
Seattle, WA
just swap in an LS1. still gonna be cheaper and less work. /ubbthreads/images/graemlins/grin.gif
Captn
Anyone ask about a budget?
That's probably something important, I think you should just restore a vr4 to its original glory. /ubbthreads/images/graemlins/gayhug.gif
transparentdsm
Cherry Hill, NJ
Quoting turbowop:
i agree with this, if your making/want to make this kind of power you should already know everything that is needed to do so and be able to tune the car as well, unless you have a bottomless checkbook, but if you did youd be in a GTR doing this and Turbowop would still beat your car.....
