This post is almost incomprehensible.
Timing falls off pretty quickly up top. I know the factory Evo maps has negative numbers on the top end, which are adders to a base timing so those numbers honestly don't surprise me. I am interested in seeing how you will both run the car WOT and use the timing gun on it at the same time. Please take video of this if you can functionally do three things at once.
Capitalization is very helpful in determining the beginning of a sentence and proper nouns. Proper punctuation is also critical in any good post where you want to get your message across to the widest possible audience. Spelling is often not as critical as the aforementioned devices, but care should be taken to minimize errors if words could be confused with similar words.
/brox
