Positive camber
overboost
Member
worcester ma
I just install my h&r spring and kyb now on my passager side it has positive camber in front
what can i do please help
Rausch
Cleveland, OH
/ubbthreads/images/graemlins/eek3run.gif
Can you elaborate on how you concluded that the camber is now positive? Is it on an alignment rack, or was it? OR is it just the way it looks?
If you just finished the install, and haven't moved the car yet (Assuming you had it up on stands) you may be jsut seeing the tire rolled over on the wheel and loaded up.
Maybe the rear just has mad negative camber now, making the front look positive in comparison.
Usually lowering/raising the front doesn't mess with camber much unless you're talking a few inches.
iLLeffeKt vr-4
NYC
Quoting overboost:
Get an alignment??
