raptorWagon
Quoting steveGLS:
Quoting rgeier11:
Don't remove the fan. Just remove the upper radiator mounts so that you can swivel the radiator. The alternator should be able to sneak out.
Don't pull the radiator, just do exactly as rgeier says. Remove the upper mounts only, and you will have enough play to get the alt out.
+1 I've never had to pull the radiator out to get the alternator out.
Quoting rgeier11:
