please help with alternator swap
raptorWagon
Oak Harbor, WA
Quoting steveGLS:
Quoting rgeier11:
Don't remove the fan. Just remove the upper radiator mounts so that you can swivel the radiator. The alternator should be able to sneak out.
Don't pull the radiator, just do exactly as rgeier says. Remove the upper mounts only, and you will have enough play to get the alt out.
+1 I've never had to pull the radiator out to get the alternator out.
Terry Posten
Davenport, Iowa USA
Yes, a wire harness.
Everything has enough flex to allow you to remove the top two brackets and pull straight up on the radiator to pull the lower alignment pins from their cradles of rubber and slide the whole assembly over to the passenger side. You only need to move it a few inches.
It really is quite simple.
Diego
^ NO.
There is just the 2 brackets. Undo the 4 bolts I'm sure there 12MM and you just lift the radiator gently out of the 2 postion/mounting/support brackets at the bottom. Don't disconnet any hose, don't do anything we didn't already tell you. Just get the 4~5 things you need to do to take your alternator out, and do it. No more questions, I want to see a post of.....
"Done!" and then everyone can gloat and feel happy we helped another one. No shoo, your typing to much to be doing anything Alternator productive.
steve
NJ
You will also feel very accomplished when you come back and tell us that its done. That's when the trouble really begins. /ubbthreads/images/graemlins/rofl.gif
broxma
San Antonio Tx
At least it's in the right section...
I have little sympathy here unfortunately. I have to pull my entire intake manifold to get my alternator out. Stop whining.
How long is this going to go on?
/brox
alansupra94
Wayne,NJ
Quoting G:
Oh nice, no heat shield.
Where should there be a heat shield? I'm not sure if I have one....also I might replace my alternator before dropping the motor because it looks really dusty and brunt out.
G
zompton
Quoting alansupra94:
Quoting G:
The o2 housing. That's probably the #1 reason why newbies are always burning out alternators. If you are running after market parts then at least have them coated or wrapped.
yeti
san diego california
Haha
Will do alternator before posting another question I do know every way to possibly take an alternator out though
I'm away from the car until I recharge a battery or two and try to drive it over to the house I'm at
Quoting Diego:
^ NO.
So true. Sometimes you've just got to stop asking questions and just do it. About 90 percent of the things you'll come across you can easily manage if you're a bit handy with a wrench. And the remaining 10 percent wich can be a cause for questions are definitely already answered...
alansupra94
Wayne,NJ
O2 housing.....not sure what does that heat shield look like? I have a shiny one over the manifold but that's about it. I might just install a small heat shield between the alternator and everything to set my mind at ease.
2of9
IGH, MN
1. remove fuel lines
2. remove wire harness
3. remove all vacuum lines
4. unbolt motor mounts
5. get engine hoist to 'hoist up' the engine
6. disconnect trans from engine
a. let the trans fall if you can
7. remove engine from engine bay
BAM...there's the alty!
