BrandonEchols
Ok, so I just picked up 12/1000 as a project.
At the least it'll need the head pulled and resurfaced, and some other this and that.
I have it in my garage now, stuffed over to one side, but it's bound to get snowy here sometime, and I'd like to be able to move the car around inside the garage (without the wheels on it) if need be.
The only two options I've found so far are:
Option 1).
OTC Car Dolly
Says they clamp to the pinch welds (I've heard using the pinch weld is a bad idea?), and roll around...
Pros: They look very stable
Cons: Expensive ($300-$350 a pair), casters don't lock.
Option 2).
Take a wheel dolly, and then weld a jackstand to it. So basically
Or something of the like.
Pros: Probably fairly cheap, locking casters (on that particular dolly)
Cons: Might be less stable than the pinch weld clamping style.
What do you guys think?
I just need to be able to move it around the garage in the winter, to access different areas of the car, and other things that would be blocked by the car if it was in one spot.
Any thoughts or experience would be greatly appreciated.
Option 1).
OTC Car Dolly
Option 2).
