Help me find the coolant temp sensor
alik
Boston, MA
If I'm correct, it's the part # MD069879 , OEM Coolant Temp Sensor (ECU)-1G DSM/GVR4.
My issue is that even on the JNZ site, the housing doesn't match the plastic shroud on my sensor. Do I have the wrong part?
alik
Boston, MA
Thank you. Unfortunately, that's exactly the sender by without the plastic housing. JNZ sells the same sender, Wyeth the same plug configuration as O'Reilly.
I was hoping for a linky to the "real" one
transparentdsm
Cherry Hill, NJ
ummm i dont know how much more "real" it can be. thats the OEM one. this is the same one and this is extreme psi click
i was just trying to save you a few bucks.
