fuel questions.
Hi so I am in the market to try and buy a full fuel kit but not sure what I all need, I want an afpr with like something that can pump 190-255 lph and I want ss lines but I am not sure what kind and then I am confused about how to hook up and oil cooler line because I hear you hook it up after the oil filter? So I guess maybe there might be some installation thread somewhere on here that as something about both of these? I couldnt find them so any help maybe?
Thanks,
PAul
the basics are wlabro 255lph fuel pump. adjustable FPR. i reccomend the aeromotive fpr since it comes with teh lines and earls fittings /ubbthreads/images/graemlins/jawdrop.gif. youll also need injectors and something to adjust your fuel maps with teh different sized injectors. a super AFC will work for that. id also suggest getting a wideband to keep an eye on your air fuel ratio as to not run too lean or run too rich and wash the rings.
jepherz
KC, Missouri
Hey Paul, I'm going to move this to newbies. Don't be offended, but separately these items have all been discussed. Try searching for "+fuel + pump" or other keywords in the search from above and see what you can find.
