Crank Bolt removal
sublimesnfu
Anchorage, AK
I ran into a bit a trouble yesterday when removing the crank bolt to change out the balance shaft belt, I couldn't get it to budge one bit, does it turn clockwise or counter clockwise like a normal bolt to loosen it?
Thanks Alan
cspetros
Port Norfolk, VA
Hi Alan. The bolt tightens/loosens normally, like you said.
Read this thread (all the way through, it's not too long): Crank Bolt removal
You'll need a breaker bar and a 22mm socket.
To retorque it: Read this thread. You'll need a transmission for this /ubbthreads/images/graemlins/wink.gif.
Good luck /ubbthreads/images/graemlins/smile.gif.
