checking timing...
SleepinGVR4
Danville, Pennsylvania
I can check my timing without taking off the timing belt cover correct? Line up the cam gear marks and line the crank pulley mark with the "T" on the timing belt cover?
Barnes
Richland, WA
What timing are you checking? Ignition timing or to make sure your timing belt is timed correctly. /ubbthreads/images/graemlins/confused.gif
broxma
San Antonio Tx
From the sounds of it you want to make sure the belt is on correctly. In that case, yeah. The method you mentioned will work. It will not, as BM said, tell you if the ignition timing is correct.
/brox
