NateCrisman
"You think your out - then you get sucked right back in"
Ok, so I picked up #610/1000 on wednesday from Tommyd up in upstate NY, and I originally had no real plan...full partout vs minor partout & sell shell vs fix & flip vs restoration to sell...I literally just knew the price was right and I'd make out on it any path I went down. So I pick the car up....the rust isn't as bad as I'd imagined, and the car is resonating with me.
F-it Im keeping it. /ubbthreads/images/graemlins/applause.gif And so it begins.
Here's what I picked up: Dusty & needs cleaning up inside and out...but Im super pumped about it all together. Took his word on it that it runs, frankly...at the price I paid, I generally don't expect a running car anyway....so if it did....gravy.
Here's a few pics after unloading it from trailer and giving it a quick hose bath friday:
Cleans up nice. Exterior wise the car is like 6/10 condition.
[*]The hood has a rusted through corner and few dents and needs to be replaced
[*]Clearcoat is failing on the roof, wing, trunk - typical
[*]Grey paint on the JDM-YO bumper covers is cracking and chipping off
[*]I don't like the chrome grill---that's going away for the proper 92 USA spec grill (i should still have one off #139!)
[*]A few minor dings, scratches... [/list]
I think my plan is to find any good condition hood and then vinyl wrap the car in a grey or silver. Im still up in the air on the bumper covers, Im probobly going to keep them until I can find a really mint set of USDM covers that aren't cut/cracked that are worth having painted to match.
Interior is 8/10
[*] ITS ALL THERE!!! both a pillar plastics, both headliner trim plastics, all the grills/covers. Nothing is missing. Even dash badge!
[*]Needs a front seat set...these are 160k mile's of worn out. Good thing I have a set in stock that's perfect
[*]Carpet is also dirty and stained. When seats come out, I'll pull carpet, powerwash, and spray dye black. Will look better than new.
[*]just needs a dusting and vacuuming while the carpet is out [/list]
Mechanicals....lots of work here. I got it to fire on friday on gasoline, but Iv got issues. Tommy said it was smoking, the bottom end is freshly built with wiseco pistons...may have issue with wrong rings. I see oil pooling in the compressor housing of the HX40. Gotta drive it to figure out where the smoke issue is coming from.
[*] Figure out the smoking issue - confirm condition of shortbock, turbo, head
[*]Fuel system is setup for big power on E85...it's way overkill for my intended daily driver use
[*]Intake/turbo system also overkill...Im planning on a 16g,internal wastegate, stock cams, stock manifolds type setup. Something for low 12's
[*]Brakes/suspension...Im not hot on coilovers on a daily driver so they will go and basic KYB's go in. Likely sell the big front brakes and put stockers on. [/list]
So, Iv got work to do. /ubbthreads/images/graemlins/wink.gif
Interior is 8/10
