1893
Demo12
Member
Spring lake nc
Hey guys picked up 1893 the other day. Shes a little rough and needs some loving but glad to be the new owner! /ubbthreads/images/graemlins/smile.gif
tombaman
rensselaer, in
Congrats and Welcome!!!
Demo12
Member
Spring lake nc
Thanks, its in Arizona (where Im from) Im in North carolina On fort bragg, so when I go home Im gonna fix it up Little by little until shes ready to be driven to north Carolina with me.
acn
Murray, UT
Congratulations and welcome. What upgrades does it have? I see a FMIC peeking through the front bumper.
pot
Fayetteville, NC
Awesome brother - I'll be moving back to Fayetteville, NC next month. We should get together in the near future. It will be nice to have some galants in the area to take to the Fayetteville Motor Speedway. Off the top of my head, there's 3 or 4 gallants in the immediate area.
rebelboost
Active member
Pensacola, Florida
welcome to galantvr4.org! I love the color and how is the body? Are you going to post more detailed pics?
bobdole
U.K.
Welcome /ubbthreads/images/graemlins/smile.gif
Demo12
Member
Spring lake nc
Quoting Pot:
Cool man, Ive also got a 1g talon. pm me when you get back.
Demo12
Member
Spring lake nc
Quoting rebelboost:
Thanks. The body is a bit rough with door dings and the passenger fender has a good dent, once I get home in the coming weeks ill be sure to post some pitures!
988
Malaysia
Demo12
Member
Spring lake nc
Alright, so my first time starting the car since I got home on leave and it started and then it didn't, also had a bad miss so I checked the capacitors and wouldn't you know. They leaked pretty good so I picked up some new capacitors cleaned it all up and no more miss /ubbthreads/images/graemlins/laugh.gif has idle issues, transfer case leaks and im sure it needs a new timing belt, smoke on start up and needs a slave cylinder. Im sure there is more /ubbthreads/images/graemlins/smirk.gif
GVR4kauai
Nice find bro!! Looks similar to mine lol!
Demo12
Member
Spring lake nc
Thanks
Has anyone ever had problems with there fuel gauge? mine is always way past full. Ive checked all the fuses im getting power to the fuel gauge but the actual gauge stays right where it is. I haven't traced the wiring yet but Im just wondering if anyone has ever had this problem?
GVR4kauai
Sound like the float is stuck bro! Id check that out in the tank and see what its hung up on or why its stuck!
Quoting Demo12:
Thanks
The float could be stuck, but it's unlikely IMO. You likely have a short to ground in the sender harness, which would peg the gauge. As the float rises in the full tank, resistance in the sender decreases and causes the gauge needle to drift toward full. A short to ground would make the needle peg, because at that point there would be no resistance in the circuit at all. Go in the trunk and pull the fuel pump access cover. Test the harness accordingly.
Fuel gauge unit resistance:
Point F 3 ohms +/- 2
Point E 110 ohms +/- 7
Access cover and pump harness:
Test procedure:
Demo12
Member
Spring lake nc
Perfect, Thanks man.
The dude that rewired the fuel pump I guess didn't know what he was doing because he cut the wire for the fuel gauge and grounded each side?
But its all fixed now. now onto the speedo.
