2.3L short block for 533/1000
BlitzVR4
Virginia Beach, VA
Been toying the idea of having a stroker short block built for the Galant. Well it's finally happening. Got these images tonight of the parts. Should have the short block next week.
I will give full details later.
New pic Ross pistons on FFWD Connections Vader Rods
turbohf
Lake Stevens, WA
aluminum rod 2.3 /ubbthreads/images/graemlins/applause.gif
love my 2.4L... was a good (expensive) move. just need to fix the rest of the car bolted to it lol.
Sexy rods....
too bad you'll never see them after the build, hopefully.
1dvsdsm
Arlington, Tx
damn, I have a brand new set of stroker pistons I was thinking about selling.... Eh ill bring em to the shoot out. Looks great! oem crank?
Near Seattle, Washington
Depending on what pistons they are, i might want them.
I need a set with a 21mm pin, so i don't have to go buying rods right away for my 2.3L build.
362Ryan
Alaska
You don't need to buy new rods. A machine shop can resize the 1g rods to 22mm.
JamesFoster
ALL
Awesome! Dem rods is perrty nicee
Also like dat crank. Same one inside my engine, turns around and cranks the rods and pistons and stuff, all the way to 100mm! Can you believe that!??
EMX5636
Bucks County, PA
Take some pics of the clearance required to run these rods in a stroker. I know how much I had to grind to fit my RNR rods in my 2.0L. Looks like a nice build though!
BlitzVR4
Virginia Beach, VA
Actually the short block is being built at FFWD Connection. Darren has been texting progress pics of the build. So I don't have any clearance specs. I am getting very anxious to put this motor into the Galant. I currently will be using a FP 68hta. Going to see how much I can push this turbo.
EMX5636
Bucks County, PA
Quoting BlitzVR4:
I didn't mean clearance specs. I'm assuming you'll have to cut the bridges of the main caps completely, as well as grind a lot of material out of the 3rd cylinder by the balance shaft. I know I had to clearance mine further than a steel rod in a 2.3. Post some of the pics he's sent you.
BlitzVR4
Virginia Beach, VA
All the images are up. I am leaving the work up to him. He did me right last time on a motor I had in my Talon Tsi.
Quoting 362Ryan:
Hell, they could probably just replace the bushing in the small end. It looks like i'm just going to buy a set of Mahle 4032 pistons for mine though. They come with a 21mm pin. /ubbthreads/images/graemlins/grin.gif
slugsgomoo
Tacoma, WA
Any reason you're building a 100mm stroke motor with no main girdle? So much flexyness in the 4G63... /ubbthreads/images/graemlins/wtc.gif
