Lost power and stalled while driving... fuel / outside heat related?
SleepinGVR4
Danville, Pennsylvania
So I had a really close call yesterday. I was I-476 when all of the sudden when I pushed on the accelerator the car just stumbled and fell on its face. I down shifted and still the same thing, just had zero power. No check engine lights or anything. The car finally stalled and I coasted the car as far as I could, within sight of my exit, but I just didn't think I was going to make it so I pulled over and stopped.
I should mention it was 100 degrees out yesterday. I tried to start it back up after I pulled over. It would turn over but just wouldn't fire. I checked around for loose wires, unplugged sensors, anything that would cause this. It was like the MPI fuse was pulled out.
Finally after about 20 mins, I tried the car again and it fired right up. Checked the fuel pressure and it was fine. I managed it get it all the way back home without a problem.
The symptoms were just like if your fuel pump died or it wasn't getting enough fuel. I did notice the aftermarket fuel pump relay was pretty damn hot. Is that normal? My battery is located in the trunk fyi.
Can a fuel pump over heat? Could the relay have gotten so hot that it wasn't supplying power to the fuel pump?
G
zompton
What kind of fuel pump? How much gas was in the tank?
ktmrider
Tempe, AZ
1g DSM buddy had same issue last summer ( car is JSB this year ). Vapor Lock. Also had same symptoms on rewired Wally, relay hot to touch.
He swapped the pump out, no more stalling however the car developed a rod knock shortly after and he parked it.
Vapor lock is rare on fuel injected vehicles because of the pressure.
ktmrider
Tempe, AZ
Quoting iceman69510:
Correct, my response was a bit cryptic.
We suspect his Wally was bad. He had a pressure gauge, it would drop to the teens and we could hear the fuel percolating. Once the engine bay and fuel pump cooled off it started right up and ran fine.
jnava
Arlington, Tx
My main question is, did you do a rewire?
Nate
Worcester, Pa
Check your wiring connections, but also inspect the fuel sock on the bottom of the pump. It sounds like the pump is overheating and will work again on e it cools off. I chased this problem years ago and the fuel filter sock was clogged terribly.
