Well I brought her home yesterday and started going over the car. It's 1390/2000. Must've had a few hands in it since I got it. The side marker wires are cut for some reason, and I noticed the rear steering has been deleted, the rear line is plugged. Lots of rust and shot bushings. At first my main concern was rust but now it's just to keep it driving. If anyone has experience with the following any advice would be much appreciated.
E-break
The E-break is not working. Handle seems to have tension and as per the shop manual pulls up and clicks 5-7 notches, but the car will still roll when engaged. I located the lines and both are connected to the rear brakes. Any advice on diagnosing this? Start with the brakes themselves?
Power steering
I have the PS pump sitting in a milk crate I was given by the last owner along with some other bits. No reservoir. I took a look at the front rack today and I felt under one of the boots that was cracked, and it was a bit wet. I'm assuming it has a leak. I found one on rockauto (linked below), and am wondering if this is just a 1:1 OEM direct replacement. Are there any how to's on replacing it? Also can't find a reservoir for the GVR4 anywhere, can I find another that will bolt right up to where the old one was located?
Steering rack
Radiator Fan
Current fan was locked up and grindy. Also found a replacement from rockauto (linked below) and am wondering if it'll be sufficient, or if anyone can recommend a better fan that won't require any modifications.
Radiator fan
For now the car's going to remain on jack stands until I can steer (and park) it safely and keep the engine from overheating. This is my first project car and it needs a good bit of work but I'm excited to get it fixed up, I'll post some pictures soon. Also my apologies if any of this has been gone over before, I'm new to these types of forums and I did take a look before hand. Thanks in advance.
E-break
Power steering
Steering rack
Radiator Fan
Radiator fan
