Trying to find Turbo rebuild
Fastmach01
New member
Clear brook
I have a MHI EVO3 BIG 16G that needs rebuild. What rebuild kits do you all recommend. If you could post links that would be great thanks
G
zompton
FlyingEagle
THE Ottawa
That looks like all Mitsu parts!! Damn....
TraderGreg was the kit I purchased a few months ago.
I may be pulling the turbo again to get that installed.
theevozero
Odessa, Texas
Each part is balanced individually from the factory. As long as you aren't replacing any major components, you should be fine.
tektic
ronkonkoma, ny
If you are keeping all the same rotating assembly it is a good idea to mark its orientation in relationt to each other than assemble aligned the same way.
