Pull engine to replace oilpump?
gvr4144
loveland Colorado
Hey guys, I'm doing a timing belt and headgasket overhual because of a crank seal leak. I was planning on doing the oilpump aswell. My question is weather or not I have to pull the block to put a new oil pump on?
thomcasey
Indianapolis, IN
I would assume not since people have performed the BSE with the motor in. I assume you already have the balance shafts gone? You will have to drop the pan for sure to un-bolt the oil pickup tube.
fuel
Toronto, ON, Canada
If you still have the balance shafts it will be hard to do it in place, as when you pull the oil pump the rear shaft comes out with it and you'll find the driver's side frame rail is in the way.
How many miles has the engine done? Is there a reason you need to replace the oil pump, such as low pressure etc? If the oil pump is working fine currently I would just leave it in place and replace the crank seal and call it a day. The oil pump is hardly a wear item like the water pump or timing belt etc. It should last the entire life of the engine.
Yup, just replace the seals. It can be done in car, but I wouldn't bother unless there was something actually wrong with the oil pump itself.
gvr4144
loveland Colorado
It's an aftermarket high volume pump made by I think Toga or something like that. The motor has about 17k but the oil pump has seemed to always whine under acceleration since I've owned the car. About 10k miles. I just really would like to go with an oem for logevity.
fuel
Toronto, ON, Canada
Follow these instructions - click
You'll need to remove the transfer case and drop the exhaust and oil pan and lower the engine down a bit.
gvr4144
loveland Colorado
Quoting turbowop:
Yup, just replace the seals. (It can be done in car), but I wouldn't bother unless there was something actually wrong with the oil pump itself.
I like Marks optimism saying it can be done lol. Seeing how I do already have a kevlar bs belt and I wanna keep the bs for smoother idle/driving, I'm going to go for it.
It's not just optimism. I've done it. /ubbthreads/images/graemlins/rofl.gif
Back in '03. Balance shaft removal. I can't remember if it's needed or not but I pulled the whole front cover and oil pump off the engine. Hard to believe but I've still never had the shortblock out of my car. /ubbthreads/images/graemlins/jawdrop.gif
tektic
ronkonkoma, ny
What are you saving from not pulling the engine? The only reason I wouldn't pull it is if I didn't have a hoist.
mitsuturbo
Near Seattle, Washington
Quoting gvr4144:
I still have my balance shaft belt for drivability. I couldn't find anything if someone has done it with the bs.
Remove them. There's no noticeable decrease in "drivability" with them removed, but there is a marked improvement in "reliability".
