motor mount location
talontyme
Portsmouth,VA.
okay so i was looking in the engine bay today and noticed that there was no lower front motor mount is that right?car has poly ds,trans,and rear mounts but nothing in the front and it also looks like it has two front cross members.
AnotherNewb
Orlando, FL
There should be a front lower mount bolted to the block and front cross member, if your missing one you need to find a galant specific one, it will be marked "344". One from a DSM WILL NOT work.
talontyme
Portsmouth,VA.
So after a little research I'am missing the lower front mount /ubbthreads/images/graemlins/mad.gif so unless someone here has one to sell it looks like the 99gst racer piece for me.
Hertz
Chicago, IL
Quoting TrendSetter:
its missing on my car too. I don't mind, more room for downpipe.
This will lead to the downpipe bouncing off the crossmember, your trans slave cylinder getting crushed, etc. Not a good idea, but I don't mind you wrecking your car.
i agree. wrecking a dsm is never a bad thing. it would probably be one of the best things to happen to me actually.
