ETACS pin outs
Spyke169
Greenfield, Wi
Does anyone know what the pin outs are on the etacs? I'm having a problem with it intermitantly working and would like to check power and ground at the etacs.
Thanks,
-Nick
Spyke169
Greenfield, Wi
The software in mitsubishi's system doesn't go back that far. My dealership doesn't have a hard copy book that old either...
Spyke169
Greenfield, Wi
Found another dealership that has a fsm. I will photocopy and scan the etacs pin outs when I get it from them. Anything else anyone needs from the fsm?
Tell them to buy them. they are still available.
Which dealer do you work for? Russ Darrow?
cspetros
Port Norfolk, VA
The second volume "Body and Electrical" of the factory service manual (can be found here: Vol.2 B&E) does not refer to the ETACS control unit specifically. It is only mentioned in the diagrams of the various subsystem's that it controls (intermittant wipers, door locks, etc.). The pinouts for the ETACS control unit can be found by looking at the circuit diagrams of each of these subsystems. The control unit also has a pin on the diagnostic port to use for troubleshooting (the manual says power windows, but it may work for the other things, too):
Here is the rest of it. Hope it helps /ubbthreads/images/graemlins/smile.gif
Door lock circuit---------------------------------------------------------------Wiper circuit---------------------------Sunroof circuit
Alarm circuit
