#671 sounds like a wrx :( what are the symptoms of bad rings?
so i thought i blew my turbo, wasnt the case, could it be my piston rings? it kinda sounds like a wrx /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/frown.gif /ubbthreads/images/graemlins/frown.gif smoke does come out but not all the time.
Chief_Mak
San Diego/Oxnard
Sounds like you have cylinders that are not firing, make sure your ignition and fuel injectors are working properly.
DR1665
Iowa City, IA
Mine did that and it was catastrophic headgasket failure.
WRX sound == dead cylinder. You remove your plug wires recently? Make sure your plugs/wires/coil/transistor-doo-dad are sorted.
broxma
San Antonio Tx
The early days of dropping a 6 bolt in a 2G were plagued with this problem. The ECU would drop two cylinders as a failsafe due to one a few things the ECU did not expect to see. At the time, Late 90's, the solution was put a variable resistor on the barometric pressure sensor wire off the MAF in order to keep the ECU from checking for it in the first place. This was one of only a few solutions, but was the easiest. My bet is one of these sensors has had it and is causing it. I cannot say which ones it is but there were a few. Try to reset the ECU, disconnect the battery and start up the car. If I am right, it should run normal for a while and then go back to what it was doing, WRX style. If you reset the ECU, and restart it with no change, look towards a physical issue, something like a dead coil which would do basically the same thing.
/brox
speedyvr4
miami, fl
normally you would first check for spark,fuel,injector pulse and ignition pulse, but since your describing white smoke, I would just skip to a compression test. First do a dry compression test,then do a wet compression test. If there is a big difference in compression between wet/dry the problem is on the bottom end, if not the problem is gonna be in your valve train.
Diego
Quoting GVR4_1057:
Mine did that and it was the ECU.
same in my 90 gsx... coil pack went south. didnt know that at the time so i sold it for only 1k... still kicking myself for it..
talon
Denham Springs, La
I agree with all comments so far. If you have a compression tester, it only takes a few min to check the compression. If it's 121 or lower....then it fails. Your looking for 164 psi or better.
While you got the plugs out, check that they are good and firing and double check the gap.
alright, yeah im gonna do the cylinder test and see what it reads, thank you fellas /ubbthreads/images/graemlins/smile.gif
mikus
Aurora IL
164 no- as long as numbers are +/- 10% or so across, and down to maybe 130's at worst, you're getting by OK.
solidviper89
Mission/ San Antonio, Texas
Quoting broxma:
/brox
Try this, this should solve issue.
4Grim
Orlando FL
Check if you are getting spark from all 4 plug wires.
I am suspecting bad coil pack or power transistor or worse case bad plugs.
If you are getting spark..then it doesn't hurt to do a compression test.
