James
Its not behind the radio like im used to finding the ECU. all the wires are ran just inside of the passenger front door jamb, is that the ECU? i can only see wires, no box. If so, how the hell do i get that out? I see the bottom two bolts behind the ocean of wires, but are there 2 more at the top?
why? I want to know if the previous owner used the original ECU when he did the turbo setup or swapped to a 90 turbo ecu or a 91+ turbo ecu, ect ect ect.
(im still trying to figure out if he used the non turbo block and turboed it or if he swapped in a turbo motor) (oil filter housing look NT but the block has a knock sensor) -__- the joys of buying a used car.
