Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » A/C line - exchange with Dsm?
tsitalon1
Member +
Galant VR-4 org Post #: 1207934 posted 05/07/15 05:34 PM     Remind Me!  Send Private Message   Edit Post
Hey guys, I've somehow managed to bugger up my high side ac connection and will require a new high side line.
Can I grab one from any 1g dsm or are these specific to the gvr4 (length)?
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (2600:1005:b15a:1) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1207936 posted 05/07/15 05:37 PM     Remind Me!  Send Private Message   Edit Post
More than likely you"ll need a GVR$ one. Pending on how bad you need it and how soon, I'll be stripping my functional AC system off the car in the near future.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1207952 posted 05/08/15 06:33 AM     Remind Me!  Send Private Message   Edit Post
I believe it may also be interchangeable with dohc gs, gsr and gsx Galants 1988-1992. Also possibly sohc models but less sure about that.
Posts: 899 | From: Fremont Ca | Member Since: 03/16/01 | IP: (24.6.21.118) | Report this post to a Moderator
tsitalon1
Member +
Galant VR-4 org Post #: 1207978 posted 05/08/15 09:46 AM     Remind Me!  Send Private Message   Edit Post
Thanks guys!
Believe it or not, I got the AC working with a broken schrader valve in the High-side port.
While I couldn't measure the HS pressure, I was able to vacuum and fill low side till the LS gauge read 30-35, 2 cans.
I will look for a new HS line as soon as time permits.
Posts: 309 | From: Montgomery Al | Member Since: 12/29/10 | IP: (158.15.255.228) | Report this post to a Moderator
Galant VR-4 org Post #: 1207980 posted 05/08/15 09:48 AM     Remind Me!  Send Private Message   Edit Post
Schrader valves are removable and replaceable if just the valve screw-in insert is damaged.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10772 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
tsitalon1
Member +
Galant VR-4 org Post #: 1207994 posted 05/08/15 10:57 AM     Remind Me!  Send Private Message   Edit Post
Upper part of valve broke off while trying to remove it...lower portion is still in and sealing....apparently
Not sure how to get it out once the upper portion (the part the tool grabs) breaks off.
715/1000
1284/2000
Galant VR-4 org Post #: 1208000 posted 05/08/15 12:42 PM     Remind Me!  Send Private Message   Edit Post
You can try to put a small hole it and use an extractor, however chances are that since the head broke off then the threads are corroded and might not budge. If you have an extractor set, go for it. Your looking to replace the line anyway, so you got nothing to lose. I'd spray some penetrating lube in the body and cover it. That might help break it up.
12yr+ Vr4 owner.
Family Guy
dsmless
gay without homosexual tendencies
96/1000
Galant VR-4 org Post #: 1208007 posted 05/08/15 01:16 PM     Remind Me!  Send Private Message   Edit Post
Any 1989-1993 galant ac lines will work. All the same
96/1000 back in the driveway jsb getting a
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (187.189.210.172) | Report this post to a Moderator
galant0933
Galant VR-4 org Post #: 1208878 posted 05/22/15 05:06 PM     Remind Me!  Send Private Message   Edit Post
What else is the same? I should be going to the yard soon to pull some parts.
Posts: 49 | From: Chicagoland, il | Member Since: 04/27/10 | IP: (107.130.17.228) | Report this post to a Moderator
467
467/1000
Galant VR-4 org Post #: 1208930 posted 05/24/15 03:44 AM     Remind Me!  Send Private Message   Edit Post
Cosmetic parts and interior parts are very interchangeable 89-93 but style may be different so there is a lot of potential for customizing to your own taste. There are basics such as the front bumper. The ones with a larger front inlet are GVR4, 93 LS bumper which deletes fog lights or JDM (possibly Galant GSX don't know). DOHC cars are most compatible in engine bay but the engine has several differences CR, cams, piston skirt oil squirters, injectors, throttle body, power steering pump which many think is an upgrade, and more. Honestly, a great many items are compatible but have subtle issues. If you see something you like on a different year/model but are not sure will fit, ask the board, probably someone will get back to you quickly.
Edited by 467 (05/24/15 03:52 AM)
galant0933
Galant VR-4 org Post #: 1208934 posted 05/24/15 02:08 PM     Remind Me!  Send Private Message   Edit Post
That's good to know. Vi meant AC parts though. Are the lines, brackets, compressor, and condenser all the sane with the 2.0's abd 1.8s?
I'm going to the yard Wednesday, and am positive they have a complete 91.
Posts: 49 | From: Chicagoland, il | Member Since: 04/27/10 | IP: (107.77.83.127) | Report this post to a Moderator
Galant VR-4 org Post #: 1208942 posted 05/24/15 03:47 PM     Remind Me!  Send Private Message   Edit Post
Different engine, so suspect the possibility the compressor mount bracket and compressor are possibly different. Don't know for sure though.
Posts: 10772 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
467
467/1000
Galant VR-4 org Post #: 1208954 posted 05/24/15 10:56 PM     Remind Me!  Send Private Message   Edit Post
Go here click to find part number of component you need.
Go here click to enter part number and see what other Mitsubishi vehicles use that part (scroll down).
Many sites like this now, use the one you are comfortable with
Banthony
555/1000
Galant VR-4 org Post #: 1209816 posted 06/10/15 09:10 AM     Remind Me!  Send Private Message   Edit Post
I'm surprised nobody has mentioned the fact that the SOHC and DOHC in NA form have the exact same block. I'm sure the compressor would have the same mounting bracket. Thus, it is likely they would run the same compressor. Therefore all the lines would likely be the same across all 89-93 Galants, be they VR4, GSX, GS-R, GS, LS or base.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (192.8.72.2) | Report this post to a Moderator
galant0933
Galant VR-4 org Post #: 1209846 posted 06/10/15 06:35 PM     Remind Me!  Send Private Message   Edit Post
Does that mean an na dohc ac system will fit on the vr4?
Posts: 49 | From: Chicagoland, il | Member Since: 04/27/10 | IP: (2602:306:b821:1e) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 1209868 posted 06/11/15 05:02 AM     Remind Me!  Send Private Message   Edit Post
Dsm's have different compressors. The dsm ones are smaller and doesn't have a pressure switch hole like a vr4. I know because I made one work on mine but required having hybrid lines made and swegged together.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (2602:306:bc76:d4) | Report this post to a Moderator
boostme
Galant VR-4 org Post #: 1246115 posted 05/16/19 04:52 AM     Remind Me!  Send Private Message   Edit Post
Does any one if a/c lines are different?
I know compressor and bracket are diff.. Hard to find this stuff that isn't priced like gold
Posts: 51 | From: Crete, IL | Member Since: 10/04/13 | IP: (2601:244:5400:43) | Report this post to a Moderator
Galant VR-4 org Post #: 1246116 posted 05/16/19 07:30 AM     Remind Me!  Send Private Message   Edit Post
Given the shape of the car and the need for the lines to follow body lines, I don't think the main hard lines are the same. Now, if the length is sufficient, they may be able to be bent to fit, probably poorly. they are fairly flexible, but you don't want to kink of fatigue them as the aluminum can crack or split easily.
I may still have a compressor bracket around if you need one. I know I sold one a few years ago.
0 registered and 48 anonymous users are browsing this forum.
Generated in 0.19 seconds in which 0.155 seconds were spent on a total of 14 queries. Turbo powered.
