Help diagnosing steering wheel shimmy over bumps
kitcho
canada
So my galant has some very serious steering wheel shake when going over bumps. It is hugely noticeable when I go over a bump or road imperfection that only affects one side of the car, left or right. When this happens, the steering wheel moves violently in that direction. When it affects both wheels simultaneously, it isn't nearly as noticeable.
I jacked up the front end and did the test where you hold the front wheels at the 9 and 3 position and the 12 and 6 position. Absolutely no play at the 12 and 6 position. At the 9 and 3 position, I am able to move either wheel somewhat which causes the steering wheel to move significantly, say 1/4 turn each way. Looking under the car while doing this, the outer tie rod was tight with no play. I am worried that the steering rack may be done for. How can i verify that this is the case?
Have you tried a fresh alignment? Grabbing the tire and 9 and 3 and moving it will cerainly move the steering wheel back and forth. That's normal.
kitcho
canada
I should also point out that my front struts are leaking oil (kyb gr-2 w/ stock springs), and the strut mounts appear to be cracked and in poor condition. My current plan is to replace the front struts and strut mounts and go for an alignment. Could worn struts and mounts cause steering shimmy?
SouthCaliVR4
North county San Diego
sounds like a ball-joint/tie rod end kind o thing. check your rack mounts too. blown strut, I think, would present in a different manor.
Noobsauce
Beaverton, Oregon
Seems like you need a full suspention rebuild anyways. Get the car in the air and check for loose ball joints and tierod ends. It's Easyer if you have someone move the wheels while your under inspecting. Also get a screwdriver or prybar and check the bushings by putting leverage against the control arms and see how far the bushings squeeze.
kitcho
canada
The outer tie rods were replaced a couple years ago. How do i diagnose inner tie rods or ball joints? How much play should there be in the control arm bushings?
tsitalon1
Montgomery Al
Quoting kitcho:
Kidding right?
Leaking struts, cracked mounts, and your worried about a shimmy!! Wow.
Rebuild the front end!
rdomeck
Indianapolis, In.
You know you have bad parts? Replace them, but put something different than KYB. The struts could very well be your problem and they probably don't have very many miles on them.
Noobsauce
Beaverton, Oregon
also assuming the outer joints are fine because you replaced them 2 years ago is a bad idea. anything can go bad in any amount of time. check it all out.
