Exhaust manifold Studs
Yes, I've searched. Read about the BMW studs and saturn studs. My questions are:
Are stainless steel studs really better? (more of an opinion)
and
What about using stainless studs with OEM copper lock nuts? Would they slip or corrode?
I ask about using the OEM nuts because the have a built in washer and the lock. Also from my searching I found the site ssstuds.com and they offer a stainless stud with copper nut combo. So is it better, what are the advantages and disadvantages of copper on stainless, and using stainless on stainless?
CutlassJim
Manchester, NH
I went with the full SS 2G set when I was putting 797 together 3 years ago and they are now the only thing in the car not rusted and came off super easy.
bigblock4g63
new jersey
i use arp stuff you can get them for $105.00 shipped
Stainless steel studs
Jepherz mentioned that link in some previous threads. I ordered a set and he swears by them. Hope they preform well.
CutlassJim
Manchester, NH
I just said I had them and they are awesome screw Jepherz! /ubbthreads/images/graemlins/grin.gif
GreenGSX
Rochester, New York
The One Lap VR4 uses stock studs with stainless flat washers and stainless nuts. I torque them down, heat cycle them a for a few days and then snug them up again. Haven't broken a stud or lost a nut in years. The important part is to brace the down pipe to the block. I welded a tab on mine that I connect to the factory point.
Dan D
Brownsburg, IN
My vote is for oem studs and nuts with all the holes reworked with a timesert. Did that many years ago and haven't had a problem with loose, broken or stuck hardware since.
