Brake problems
alik
Boston, MA
Pushing the pedal at rest, and it goes down all the way. I just swapped a new master, and bled 4 corners. ABS is disconnected, but, impossible to bleed (too far up the ass).
The car stops perfectly fine. I used Motive Power bleeder and ATE Blue. I've got a rejected sticker because of this crap.
Anyone have any ideas?
toybreaker
iconoclast
Did you bench bleed the master?
alik
Boston, MA
With power bleeder (pressure bleeder), there's no need to bench bleed the master (have done this many a time on the race car (Miata))
Same size master cylinder?
alik
Boston, MA
Yep.
Chatted with toybreaker, it's the ABS unit.
ABS delete, braided lines, will report after that.
toybreaker
iconoclast
Nice talking to you, Al /ubbthreads/images/graemlins/smile.gif
Since Al isn't going to be using the abs system, he's going to delete it, replace the prop valve and fab up some new lines.
Replacing the rubber lines at the age and mileage his car has just makes sense so he's going to do that as well.
I'm betting that will make everything golden. /ubbthreads/images/graemlins/cool.gif
If it doesn't he'll be checking the individual rotor temps with a pyrometer after a test drive to see if it's a caliper problem.
[edit] Good question, Dave!
alik
Boston, MA
Looking around, it's easier to find Jimmy Hoffa than a proportioning valve from GSX.
I'll have to search for DSM AWD unit.
Well, did you find Jimmy? Otherwise, they appear to be equally futile, perhaps?
toybreaker
iconoclast
Ever notice that odd bump at mile marker #217, e.b. on the massapajoisey pike?
Kinda makes you go hmmmmmm, don't it? /ubbthreads/images/graemlins/wink.gif
Adorsey
mass
Lol jimmy.. Did you check your local junk yard for the valve? I'm going to mine this week to do exactly that. Just got a NT tb on friday from the same car.
Good luck
I picked up my prop valve and brake lines from a non-abs fwd Galant in a junkyard, and IIRC it had disc brakes. I had to tweak the lines a bit to fit in the original clips.
