Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Washer Reservoir relocation?
blkchr91
Galant VR-4 org Post #: 1119655 posted 04/23/13 03:01 PM     Remind Me!  Send Private Message   Edit Post
Has anyone relocated their washer reservoir? I plan on trying to utilize my stock 1g can and filter along with an ETS intake. I anticipate the washer reservoir being a problem.
Has anyone moved it?
| | | IP: (71.63.73.193) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1119662 posted 04/23/13 04:12 PM     Remind Me!  Send Private Message   Edit Post
Once I remove the ABS I'm going to find a bigger bottle that will bolt into the wheel well and only the neck will be visible.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1119696 posted 04/23/13 07:29 PM     Remind Me!  Send Private Message   Edit Post
I used a stock 1G bottle. Mounted in the pass side wheel well. The factory neck sticks up through a hole already there behind the headlight. Extend the hose and wires, done. And looks factory.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.135.121) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1119697 posted 04/23/13 07:36 PM     Remind Me!  Send Private Message   Edit Post
Some of the pics are old and previous setups. But it's never been in the way and works great.
91 #108/2000- link
05 CTS-V
09 Hummer H3T
Edited by EMX5636 (04/23/13 07:37 PM)
475/1000
Galant VR-4 org Post #: 1119813 posted 04/24/13 01:41 PM     Remind Me!  Send Private Message   Edit Post
Quoting EMX5636:
Have the exact same thing
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.150) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1119815 posted 04/24/13 01:50 PM     Remind Me!  Send Private Message   Edit Post
Quoting blkchr91:
I was going to try and get my hands on one of the RHD ones as seen in this photo, and mount it where the resistor pack sits, but i wound up making the stock bottle/location work for my setup. I may end up putting something in the ABS spot, now that mine's open.
Edited by mitsuturbo (04/24/13 01:52 PM)
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.91.91) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1120543 posted 04/28/13 08:34 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the pics everyone. Is there any way to relocate the stocker and still have it look half way decent?
Edit: Just realized that is the stocker...lol.
Edited by blkchr91 (04/30/13 09:54 PM)
715/1000
1284/2000
Galant VR-4 org Post #: 1120556 posted 04/28/13 09:18 PM     Remind Me!  Send Private Message   Edit Post
You could extend the wiring and the washer hose to the trunk and put it back there....
I'd use a couple one way valves to keep the fluid in the line so it wouldn't take a minute to start spraying.
12yr+ Vr4 owner.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (24.230.60.72) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1120595 posted 04/29/13 12:51 AM     Remind Me!  Send Private Message   Edit Post
What about somewhere in the engine bay...like maybe where people are putting their 1g bottles?
| | | IP: (166.123.216.29) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1120614 posted 04/29/13 09:05 AM     Remind Me!  Send Private Message   Edit Post
The advantage of the 1g bottle is that it has a long neck to allow the bulk of the tank to get mounted out of sight. Since our reservoir doesn't have the neck you can't mount it low and out of the way. The only real other place would be near the P/S tank and abs, but then you would have to delete the P/S for room. You could go to where the stock battery sits, but your intake may suffer.
12yr+ Vr4 owner.
Family Guy
matt92vr4
Member ++
474/1000
Galant VR-4 org Post #: 1120629 posted 04/29/13 10:08 AM     Remind Me!  Send Private Message   Edit Post
I've not tried this, but 1999 3000GT tanks are hidden in the front grill area near the hood latch. If they fit in a Galant, it would be a nice place to hid one. The 91-98 is similar to the 1G TEL with the long neck.
474/1000 Summit White
1993 Stealth RT/TT
1995 Montero SR
1998 Montero
Posts: 676 | From: Venice, FL | Member Since: 10/03/10 | IP: (184.4.224.174) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1120632 posted 04/29/13 10:40 AM     Remind Me!  Send Private Message   Edit Post
There is a pull and save near by that should have a few of these laying around. If anyone wants one let me know. Im sure it will be cheap. Shipping will about 20 bucks due to the size.
12yr+ Vr4 owner.
Family Guy
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1120959 posted 04/30/13 08:26 PM     Remind Me!  Send Private Message   Edit Post
Quoting mitsuturbo:
Quoting blkchr91:
Are you going to relocate your brake booster and master cylinder to the passenger side so you have room for the JDM reservoir?
The 1G tank looks baller behind the headlight. I'm totally stealing that.
I love my crazy mother!!!
Edited by CutlassJim (04/30/13 08:27 PM)
Posts: 1598 | From: Manchester, NH | Member Since: 07/17/06 | IP: (75.69.152.105) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1120968 posted 04/30/13 09:54 PM     Remind Me!  Send Private Message   Edit Post
Yep this is what is happening to me now. I could drop it lower and jb weld it to the frame but can't imagine how I'd be able to get washer fluid in there. I think it would be annoying to use a long funnel to get washer fluid in there but I am leaning towards it. Hell, I have to use a funnel to get coolant into my Escort GT. I should already be used to it.
Quoting prove_it:
Edited by blkchr91 (04/30/13 09:56 PM)
715/1000
1284/2000
Galant VR-4 org Post #: 1120984 posted 04/30/13 11:12 PM     Remind Me!  Send Private Message   Edit Post
Hopefully your not adding coolant as much as you would be washer fluid.
12yr+ Vr4 owner.
Family Guy
blkchr91
Galant VR-4 org Post #: 1120986 posted 04/30/13 11:26 PM     Remind Me!  Send Private Message   Edit Post
You'd be surprised!
Galant VR-4 org Post #: 1121007 posted 05/01/13 03:23 AM     Remind Me!  Send Private Message   Edit Post
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (223.130.62.194) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1122651 posted 05/09/13 04:00 PM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
Quoting mitsuturbo:
Quoting blkchr91:
No, i would have taken the crap off the firewall on the passenger side and mounted it next to the wiper motor.
97 CBR900RR
2012 Hyundai Veloster
blkchr91
Galant VR-4 org Post #: 1122662 posted 05/09/13 04:44 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the pics. I got a Blox filter for an EVO 8/9. While about 6 inches long it nests right against the washer reservoir so perfect.
Quoting cheekychimp:
| | | IP: (71.63.107.192) | Report this post to a Moderator
Generated in 0.171 seconds in which 0.102 seconds were spent on a total of 14 queries. Turbo powered.
