What is stock base idle?
SmoothCustomer
Lexington, KY
Totally stock car besides the boost leaks. What is stock base idle on these cars? I'm idling at about 2,000 right now which I'm sure isn't right.
Thanks
Rausch
Cleveland, OH
Check VFAQ /ubbthreads/images/graemlins/wink.gif It's a little more involved. Not much, but a little /ubbthreads/images/graemlins/smile.gif
Edit: here it is click
GVR4_1057
Brucetown VA
Ground the timing plug, and ground the diagnostic pin (or hook up you logger)and then set to the desired RPM. This sets the ISC to a set value .
Quoting Charles:
Your Base Idle Set Screw (BISS) O-ring is probably shot, causing the high idle.
Yeah, that's probably all it is. /ubbthreads/images/graemlins/hsugh.gif /ubbthreads/images/graemlins/rofl.gif
It could be any number of things that include vacuum leaks, idle switch, FIAV, ISC, etc. Not just the BISS. Check them all.
