Vibration I can't seem to diagnose
thomcasey
Indianapolis, IN
I suggest swapping out the Torque Solutions solid mounts for some factory mounts and check. Though they are good mounts, they allow driveline vibrations to be transferred directly to the body. I just swapped out my TS solid mounts and put in stockers. No more vibration
turboneon
greenville sc
It is dss and I don't think there was any balancing that we did. It seems like it really only does it bad around 4k rpm. Full throttle isn't near as bad as slow driving.
turboneon
greenville sc
Just called the dss and the said try to rotate the aluminum shaft 180 degrees. That everything is balanced and shouldn't have to be balance when assembled to existing shaft.
curtis
Clarksville TN
bolts holding diff to subframe
pinion angle
pinion nut tight
diff bearings
did someone or you fill the carrier bearings with rtv or window weld urethane.....this can cause bad vibrations
t case mount bolts
is the front axles clicked in all the way
thomcasey
Indianapolis, IN
I was hearing the same thing^^^^^^^^^
transparentdsm
Cherry Hill, NJ
if the exhaust isn't completely attached that could cause vibration and if its smacking the driveshaft that would def cause vibrations.
turboneon
greenville sc
I looked under the car and it had clearance all around. The only hanger not on is the one that bolts in on the driver side of the car. The hanger would not reach. I'm guessing bc of the cheap eBay downpipe I got. I just went and shook the exhaust as much as I could and it never hit anything. I can hear the clunk just by spinning the ds by hand and make it stop abruptly.
marvinmadman
Lafayette, Louisiana
Is there by any chance a balance weight that is tapping the exhaust at the perfect time when the shaft is flexing?
