kingpsycho
Member
well i have been working on ma galant trying to get it to run well and it has but now i just have questions on ma tuning wen i bought the car the guy told me he had tuned it at ams and made 298 whp and 301tq but it was all before he installed injectors fuel rails fuel pump.... he gave me an ecu with the car and i decided to go ahead and put it on but not sure wat that would do to the tuning the tuning was done on an afc neo by the way... he gave me a sheet of paper with like i guess the mods on the new ecu they are as follows...
keydriver
7500/6000 selectable stutterbox
default is 4500
a/c cut out
rescaled mas
640cc injectors/264us deadtime
knocksum gauge
fed/awd
2x karman
anti-stall code
44psi base fuel pressure
uppper image has 11:1 a/f and extended pumpgas maps
lower image has 11.5:1 a/f and race gas timing maps
e943 gr-4 no fuel cut
4250/4500/4750/5000/5250/5500/7800
stock 2g mas
enhanced closed-loop maps
shift ce light at 7000rpms
800 rpm idle
no airflow cap
rescaled trims
fixwd 2g iat mappk+ code
dual image
i have an idea wat all that means but if anyone could explain further wat i got that would great and do u think this would create problems with the afc since it was already tuned without the injectors and stuff?? /ubbthreads/images/graemlins/dunno.gif
keydriver
default is 4500
a/c cut out
rescaled mas
knocksum gauge
fed/awd
2x karman
anti-stall code
stock 2g mas
800 rpm idle
no airflow cap
rescaled trims
dual image
