I do have an Orchard supply, ISO JIS? The reason being is after i switched the trans my old bolts didnt fit in the new trans, and I have no idea why. /ubbthreads/images/graemlins/dunno.gif
Sounds like the threaded holes on your new(er) tranny are stripped. Pretty much every Mitsu that I have seen from that era has the same size bolts holing the tranny mount on. There should be enough material there to drill/tap if thats the case. Or maybe a slightly longer bolt. I think the ones that hold the cam gears to the cams are a little longer.
The wad of the bolt is a 17mm, I don't think it's an oem bolt in the first place, and not sure about it being a 2g tranny. The new one is from uncleben on here and it's a tre stage 2.
-shane
