TPS, and ISC grounding/
Adorsey
mass
I know that I have to ground the- ignition timming adjustment plug, and the diagnostic plug under the dash, but where do I ground them too if my battery is re-located in the trunk? /ubbthreads/images/graemlins/dunno.gif
TIA
1990ggsxnj
Blackwood, NJ
What do you need to ground them for? If you're doing an idle adjustment, just ground to the engine or body(both cases).
Adorsey
mass
All the posts I had read about adjusting the idle speed said to ground it out before adjusting, I was just wondering about, where to ground them too.
Thanks for answering my Q. /ubbthreads/images/graemlins/smile.gif
/ubbthreads/images/graemlins/rofl.gif You don't have to run a wire to the negative terminal on the battery. Just anywhere bare metal on the chassis really. There are plenty of ground locations in the engine bay to choose from.
