SETTING MY +FUEL PRESSURE REGULATOR CORRECTLY
chop91vr4
new haven indiana
Okay so I have searched and searched the web and I can't find anything to follow as per how to properly set your fuel pressure, just as for a basic's but I know I have a 255 fuel pump, 560CC INJECTORS and a AEM fuel rail with regulator /ubbthreads/images/graemlins/banghead.gif
EHmotorsports
Beaverton
remove vacuum source and plug to prevent an air leak. start car and adjust to factory spec if you are not running ECM link. after pressure is adjusted reinstall vac line to regulator.
You can also activate the fuel pump using the jumper terminal on the firewall (or activate with ECMlink). After the pump is on, set the pressure.
chop91vr4
new haven indiana
Quoting EHmotorsports:
it's currently set right about 40 is that close or should I back It down closer to factory?
