Riddle me this... Water pump
SleepinGVR4
Danville, Pennsylvania
Isn't Aisin the OEM water pump manufacturer?
Then why is it so much cheaper on rock auto compared to getting it from Mitsu? Is it actually the same pump?
Here is a screen shot since I can't post a link to rock auto. Its the second one up from the bottom.
Here is a link on the pump from rock auto.
ercp98
northlake in illinois
that is the unit i ordered from them. it had aisin stamped on the pump housing.
i would also add that i ordered the beck arney pump too. but that did not fit properly.
theevozero
Odessa, Texas
I don't know if it would be the same, but I ordered my parking brake cables from them and they turned out to be oem, in the original packaging. I would have to guess that it's the same sh*t in a different box.
ercp98
i can't speak for the oem gasket and o ring.
but the aisin pump from rock auto is what i am running now. 1500 miles and so far no issues. the gasket and o ring that it came with all looked like it came from aisin. even the box was from aisin. it was not a repackaged item.
i used the gasket and o ring that came with the aisin pump.
hope this helps.
holeshotmoe
MD
Bought an Aisin clutch MC from rock and turned out to be identical to the OEM Aisin I was replacing. Ordered a couple trans shaft seals and inside the package were oem mitsu packaged seals. Deal by me!
JCorbo25
Sacramento, CA
I heard good things about the Gates water pump from DSMers, so I ordered one. Should be here next week.
G
zompton
Does it have the metal impellers or the plastic impeller. That could be the difference.
