replacement clutch
hi i just got a vr4 and the clutch is slipping i think i need a replacement one. Any suggetsions of brands and estimates?
GVR47111K
80022, CO
This question gets asked a lot. Do a little bit of searching up there ^. The big black bold letters, also, try Search's good friend Library. Look for what you need. Do you want stock or something to handle 500hp?
Anyway, Southbend.
i have a 16g turbo i nwas going to buy a act clutch kit but it costs over 400 bucks im lookig for something cheaper but with quality
GVR47111K
80022, CO
Quoting GVR47111K:
This question gets asked a lot. Do and little bit of searching up there ^. The big black bold letters, also, try Search's good friend Library. Look for what you need. Do you want stock or something to handle 500hp?
Anyway, Southbend. .
Up there. The page is displaying DSM clutches.
thanks guys,is this a reliable brand?
any suggestion on where i could get this installed out here in vegas?
GVR47111K
80022, CO
Hey it was no problem, it was a team effort.
Personally I've never run a Southbend unit, but I would, and others have and I bet if you check out that Search part of the forum again you could probably find a decent amount of info.
If all else fails, try the same question over at dsmtuners. /ubbthreads/images/graemlins/devil.gif
thanks again im just a little hesitant from buying because im no too familiar with the brands im scared that it wont work/fit.
can you give me a link?and do you anyoone here in vegas that can install it?
Jason G.
Anderson, SC
All turbo DSMs use the same clutch, fwd/awd, '90-'99.
Most performance clutches start at around 350. An ACT 2100 kit is right around 350, a 2600 will run about 450.
The Exedy stage 1 is around 300 bucks and should be fine for you, at least for now.
dmj
orlando FL
I can sell you a new Valeo clutch kit, Pressure plate. disc and throwout bearing for 75.00 shipped.
gvr4ever
central Indiana
Does the car have any mods? Sock?
I put a factory clutch on a old turbo talon with some extra boost and IC/exhaust mods. Non abused, it never slipped under WOT once the clutch was all the way out.
