quote:Originally posted by theymightbegalants:
Doug, why do you say that short pipe routing has no affect at all on power or performance? It seems to me, that with the stock routing going over the hot manifold, it can absorb a lot of heat and then transfer that to the charge air. Not only is hot air less dense, thus less potential for power, it's more likely to knock, which not only robs power (timing) but is damaging. Also, the short piping uses less pipe, obviously, so there's less distance for the air to travel from the turbo to the TB, improving throttle response. Do you think this is untrue? If so, you could have 10 feet if IC piping wound spiral fashion around the manifold and downpipe, and this would be no more detrimental than a short IC pipe route? In theory short route piping seems that it would be better, but from I’ve seen in the real world on Galants and some DSMs cars that run very fast at the track and dyno some good number with stock routing pipes the shorter piping doesn’t make a difference.
