Post pics of your gauge setups
Im starting to buy all of my gauges and i would like to see some different methods of mounting them
also if you could give a little info about your setup that would be very helpful
4thStroke
Vancouver, WA
The left gage is an Autometer boost/vacuum gage. The right one is an AEM wideband. Both are mounted with Autometer pods. I was able to mount them to the speaker cover easily. I have a switch mounted on the dead cover by the defrost switch to turn the light off on the Autometer and turn off the wideband altogether. The light bothers me sometimes at night.
boostedinaz
Scottsdale, AZ
My set up when I owned 1101.
evo8ya
PA/MD
nice^^^ I like the serial cable setup /ubbthreads/images/graemlins/applause.gif
On 1051 my Defi boost and egt gauges are mounted in an Aeroworks A-pillar with the controller mounted under the stereo. MaftPro screen is in the change holder in front of the shifter. The wideband readout is in the ashtray location. I have a new 52mm PLX gauge ready to go in this spring that I will mount on the steering column though. The old setup will go in 503.
In 503 I mounted cheapo Prosport boost and oil pressure gauges in gauge cups on the dash speaker grill.
jwberry
Member
Canton, MA
I have a Autometer boost gauge integrated into the cluster and Prosport boost, AF/volt, and oil pressure in a NewSouth din panel under the radio.
curtis
Clarksville TN
Quoting evo8ya:
Thanks I cut it /ubbthreads/images/graemlins/grin.gif
Polish
NE, IN
1186 a few years ago, I like gauges. /ubbthreads/images/graemlins/hsugh.gif
jepherz
KC, Missouri
Quoting Polish:
You're missing an altimeter in there, Corey! /ubbthreads/images/graemlins/wink.gif
Struc
Oconomowoc, WI
I posted this in another thread, but I guess I'll post it here too. I also have a Boost and A/F on my pillar. The A/F will be replaced by a Wideband setup at some point.
curtis
Clarksville TN
Quoting GreenGSX:
Thanks Curtis...
Your Welcome.
I have a new design drawn and started the code already so hopefully this spring version 2.0 will be released for everyone. Have about 12 hours in the drawing and making corrections because for the cutter width. No teaser pictures yet, you'll have to wait until ones cut. /ubbthreads/images/graemlins/grin.gif Main reason I've been trying to get the post processor stuff sorted on the mill so I want have to write code but just let my cam software do it for me.
4Grim
Orlando FL
Its a bit different now...Greddy TT is gone and some minor changes.
cheekychimp
East Sussex, U.K.
Total of 8 readouts
Pod Gauge has Oil Temp, Oil Pressure, Water Temp and Fuel Pressure courtesy of Twin SPA dual digital gauges
Twin Boost Pressure and Exhaust Manifold Temp in the centre three Defi Gauges (still sourcing the black bezels for these!)
And the PLX wideband custom ashtray location requires a little more work to get it to sit perfectly flush but once recessed properly and painted black should finish things off nicely.
Edit: Curtis was responsible for the ashtray mount if you want one of those.
Boostdtalon
Buckley, Wa.
had to make some mods to the bracket. So it will seat flush with the dash once i install the bracket. this will do till then.
