moduleunknown
As I'm sure most know, Prothane's front motor mount is no longer the two inserts that compliment the factory mount, but rather a solid piece that needs to be pressed in.
Before I pass the point of no return and cut out the metal sleeve, I'm wondering if anyone thinks that I might run into any problems being that the bolt hole for the original mount is off center and the prothane is centered. All three other mounts will be replaced with Prothane pieces and I don't imagine there will be much give being that they're solid and pretty firm. I just don't want to have a problem getting the bolt through the front one when then engine goes back in. What do you guys think? Install this one, or leave it alone?
Maybe I worry too much... /ubbthreads/images/graemlins/dunno.gif
