Need help finding bolts
ducttapeguy
Hey all. Im looking for 2 M8 1.25 x 90 bolts. The ones I have are bent to hell. I went to Autozone, Home Depot and Lowes and couldnt find any in the right length or grade. I need them as soon as possible. Any Ideas?
DynastyLCD
what exactly do you need them for?
ducttapeguy
My HKS turbo kit. I partially disassembled it to get at the broken bolts in it and when these came out I saw that they were bent at the threads. I want to put nice new bolts in when I reassemble it but I cant seem to find them around Watertown, NY
JNR
Are these the turbo to manifold bolts? Usually those are M10-1.25 x 80 mm, fwiw...The manifold to head is M8-1.25 though, although wow that is a long bolt (stock studs are 40 mm IIRC)!
ducttapeguy
This is the bolt. They go through the O2 housing into the turbo on the HKS kit
JNR
Ah...forgot about those bolts, although wow seems so small.
Anyway, if you know somebody with a mcmaster-carr account, they sell them and I'm sure Grainger does as well (anybody can buy from them, I believe)...otherwise, more than likely you'll need to find something online that sells small qty., or maybe HKS, etc...that is sort of an oddball size that I highly doubt you'll find at a neighborhood hardware store (esp. a chain)...you *may* be able to find something at one of those mom and pop style that sells a lot of different hardware.
I have a lot of hardware in metric, stainless, etc., but don't think anything in that size...I'll double check tho.
EDIT - the longest ones I have are 60 mm, but they are new...don't think that's be near long enough.
btw - an alternative is to get some M8-1.25 studs and nuts, etc., fwiw.
curtis
All out of 90's but these are 92. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/rofl.gif
Grade 7 if you can live with that and I can get them off to you tomorrow. Send me a PM with your address so I don't have to look it up also let me know if you need any other ones. But for future reference these hold ac compressors to the bracket.
mitsuturbo
Those look suspiciously like the bolts that hold the A/C compressor to the bracket.
ducttapeguy
Curtis has hooked me up! I should be throwing this thing back together in a few days. If I dont get my issues with the current setup sorted by then then I will be putting the HKS kit back on and taking down the FS add. Thanks again Curtis and everyone who helped me out with this jazzery
bigblock4g63
theboltdepot.com
bigblock4g63
fast shipping
ducttapeguy
Sweet, thanks. I will keep them in mind when I need more bolts
misterfixit
Scrape the sh*t of the head markings. make sure they are of the same strength/material!
Rich
