Need help deciding on intake routing!?!
CarRacer
Shakopee, MN
That looks good. Props on keeping the fog lights too. Those empty holes look funky if you ditch them.
The battery I got at Walmart for $24.99. It's a lawn mower battery. I've had it for a few years now & it only died when I let it sit for months without starting it. Charged it back up for 20 mins & it's rock solid.
I also have the same battery in my wife's 99 5 series bmw. The bmw battery took a dump so I yanked the one out of my car & put it in. My wife drives 40mins each way to & from work & I thought for sure this battery would have died by now but it's holding it's own.
Batteries can be tempermental & the same brand & type will sometimes get you different life span. Here in the summer heat is a good way to test how well a battery will hold up.
fivestardsm
Middle, Michigan
Quoting CarRacer:
Yeah, I want to keep the stock apperance of everything. Granted, I might have changed my mind on the whole stock apperance if the car had ever been hacked on or modified. The fogs are shot, but I will get a pair someday. Im not really looking for a set right now because its just not as important to spend the money on them until I can afford them.
Garfield, would you happen to know what the part # on the battery is? If not, no big deal.
Struc
Oconomowoc, WI
You could move your washer bottle and do it like the ETS kit...
mitsuturbo
Near Seattle, Washington
WTF is up with that pic you linked? That looks like a 2g intake manifold. /ubbthreads/images/graemlins/dunno.gif
I ended up buying a Miata battery from advanced and making a bracket that set the battery on the cross member below the fuel filter. welded a few brackets to hold it and it works awesome. I also had to extend the battery cables to make it work. This allows me to run a 2g maf with a normal dejon intake pipe. I can snap some pics of you want. Ive also seen the JMF battery kit and its a nice piece if you want to go that way also, I went the cheap way.
fivestardsm
Middle, Michigan
Quoting Struc:
I saw that aswell, where do they move the washer bottle tho?
fivestardsm
Middle, Michigan
Quoting 229of1k:
Yeah, if you could get a pic, that would be good. Im still not set on which setup for 100%.
Struc
Oconomowoc, WI
Quoting fivestardsm:
Quoting Struc:
Well, since you're dead set against moving the battery to the trunk, how about moving the washer bottle to the trunk? /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif
I don't actually know where they recommend moving it to, but I would imagine you could put it just about anyplace there is room, and just extend the line to the first coupler near the hood.
fivestardsm
Middle, Michigan
^^ Good point! /ubbthreads/images/graemlins/rofl.gif It would fit in the trunk.
I just wonderd because I thought maybe they suplied a bracket to relocat the bottle somewhere. /ubbthreads/images/graemlins/wink.gif
C'mon Curt, being in Wisconsin and owning a 2g with the washer bottle in the trunk, you KNOW you don't want that situation. I hate the freezing up every winter in my 2g Spyder.
Struc
Oconomowoc, WI
HA HA... Joke's on you. The 1996 Spyder GS has the washer bottle in the engine compartment, right where the stock Intercooler is supposed to be. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
Maybe you can retrofit yours? It's the ballin setup ya know! /ubbthreads/images/graemlins/tongue.gif
EDIT: Here is a picture - you can see the filler neck: click
Here are the pictures of my battery setup. Hope this can help. It cleared up a TON of room for me.
fivestardsm
Middle, Michigan
Thanks! /ubbthreads/images/graemlins/smile.gif
fivestardsm
Middle, Michigan
Well guys, I haven't concede'd yet, but after just seeing this picture a moment ago of supervr4's 89 ZR4, I am leaning toward the battery in the trunk. The real selling point is the fact that I just built my intake box, and it looks alot like that one, and I do like the clean looks. Hell, It almost makes me want to remove my cruise! (almost, not quite)
So, I haven't been tottally swayed, so I'll post up some pics tomorrow of what I have with the battery in the bay still and let you all see.
fivestardsm
Middle, Michigan
Well here is what I have so far.
