mini gauges?
Brunoboy
San Bruno,CA Home of SFO
anyone have Mini Gauges? since I wanna use the dash pod, i want to put three mini gauges if possible. Boost, EGT and Oil Pressure. anyone know of a place to get these gauges? Thanks
-Shane
Dialcaliper
Bay Area, CA
Autometer makes a 3-gauge panel using 1-1/2" electric gauges, but it's fixed for oil pressure, voltage and water temperature.
You can purchase them together, or individually if you look around at places like Jegs. Google "Autogage 2391" for the combo and "Autogage 2354" "Autogage 2355" and "Autogage 2356" for the individual units.
They also sell mechanical versions, but running hot oil and water tubes to the cabin is never a really great idea.
There are a few others like this out there, but the choice of gauges are basically the same. Note, it should not be hard to wire up a "water temperature" gauge to monitor oil temperature, as they are basically the same thing (just put a sticker on it that says "oil" if you have to).
Brunoboy
no its because i have that dash pod now, and I run three 52mm gauges already in a pod made by curtis. but I want to get smaller gauges for the dash pod and put a double din in my car so i can watch dvds and ish on long drives and during those boring nights kicken away from home.
