maf
ok i been looking at other setups people have on there intake system and they have this small maf about 12" or less away fom intake manifold and on my car i have this big huge one thats like the size of the turbo its rediculis so what else do people use. try to get some pics of my set up
1990ggsxnj
Blackwood, NJ
You're probably seeing a GM MAF which would have to be used with some sort of modification to the ECU or a translator (which just tricks the ECU). If you're just running a stock setup there is no need for it really.
Please be punctual and use capitalized letters so we can tell when a sentence is ending and beginning.
EDIT: I see you're running a 2g MAS from another post. I would recommend you stay with what's working until it stops working for you. In that post you stated you're running a stock setup. Are you just running 550 injectors to compensate for the 2g MAS?
